I would but Id need a translator
Wish they'd have asked my opinion on Bhaco stuff !
Are you guys saying that Bahcos quality has gone out the window?Used to be good but now are made of chocolate????
im not that bad. geordie land is 10 miles away!I would but Id need a translator
If their (+) (-) screwdrivers are anything to go by yes. I bought the small size to fit the earth bars in C/Us from various makers including them and they ALL just sheared off within minutes of use.Are you guys saying that Bahcos quality has gone out the window?
Toss. I quite like their gear, haven't had to buy any for a while tho
Still think Bahco make the best shifters, but I didn't rate the insulated screwdriver set from Bahco, they were made from a metal that had the hardness of chewing gum. I have a pair of Bahco snips and they are OK.Are you guys saying that Bahcos quality has gone out the window?
Shifters?Still think Bahco make the best shifters, but I didn't rate the insulated screwdriver set from Bahco, they were made from a metal that had the hardness of chewing gum. I have a pair of Bahco snips and they are OK.
Shifters?Shifters?
"Its the taste!"Shifters?
Taken from the old PG Tips advert....the one with the Monkeys in it!
Whilst trying to get the Piano down the stairs, the lady of the house shouted out..." Coooeeeeee Mr Adjustable wrench/spanner invented and patented by the BAHCO corporation, would you like a cuppa"
It was decided to shorten this to Mr Shifter, and so the expression was born!
Make sure that if you Googlr the word Shifter or Mister Shifter that you do not erroneously substitute a T where there should be an F!
Mind you, Mr Glitter is being 'careful' in the shower now so you should be safe...there again ther are still a lot of 70s 'celebrities still out there awaiting the early morning knock at the back door
I had a pair of those and still use them everday, I reckon theyre pretty goodI am a winner , maybe they will send a pair of sidecutters to replace the last carp pair they sent when i won here last time also.
