I recently did an EICR and found a fused spur acting as a light switch for a cupboard light under the stairs off the kitchen ring final, and from that there was a socket added just outside the cupboard, now I know spurring off a spur is not acceptable but the distance between the kitchen and fuse spur is the thickness of the dividing wall and the socket is situated about 3 metres away how much of a danger would you say this could be as I'm sure it would only be used for a hoover or something like a lamp, how would you guy code this a C2 or C3 thanks in advance
