androiduk2002
- Nov 7, 2009
- 840
- 0
Ok as you know I an new to the trade and trying to learn well ahead of my time in am sure but I have questions.............where better to ask them .
When chasing cables into walls how deep you do go ? I know the OSG quotes 50mm but is that the standard ?
After chasings do you then clip or is this done by the use of capping ?
I am sure I might learn the "right way" at college in time but things are not always possible the "right way", also be it right or wrong I have been looking at the screwfix catalogue and only one of the wall chasers cuts deep enough to achieve 50mm ?
If its a new build do you go 50mm into bare block work (some do still build proper houses )or do you allow for plaster ? and set it at say 45mm ?
Thanks in advance.
Thanks in advance.
