So I go there and have a look expecting them to have an old CU with 3036 fuses.... but how wrong was I......
This is what he showed me... after I had removed a couple of cables
close up of the cable
at the top there was a joint which had burnt out as well
other half of the joint
and this is the incommer... I did not touch this before taking the photo
All the 30A fuses had 2.5mm wire, the 15A fuses had 30A fuse wire and the 5A fuses in the other CU had flex wire... oh and the lighting had fused neutrals... anyway I fitted the correct fuse wire in the fuses (leaving the wire in the neutral fuse)
After sorting out the immediate problems I gave him a "Danger notice".. I'm booked in to sort out the problems in a week or two
EDIT... forgot to say that the reason this cable burnt out was due to a L conductor behind a socket having a bit of damaged cable and welding it's self to the galv box
