Cannot Get Online With Desktop Pc ..any Ideas ?
Evans Electric
TEF LINUX ADMIN™
Sep 15, 2008
23,507
527
Birmingham
Laptop is online with Wi-Fi    desktop won't connect .
Just spent 1 hour with BT man in India  who decides its the lead between hub and PC .changed that  still no good ..just trying shutting down & Start up again .
PITA . :C :(
Can you post some screen shots ?
What errors or screens are you getting ?
Have you tried with a different browser ?
Try clearing the browser cache.
Is the gas getting low,?
Maybe try another couple of turns on the key, careful you don't break the spring tho....
Sorry, I know about as much with computers as Brian :C
is it a red cable you have used to try and connect the pc to router with?
I have one came with a BT router, it wont work, apparently they are for some stupid fibre thingie or something and dont work properly with a normal port in a normal hub,
no idea why, but apparently some of them are ok, and some not,  :C
so what happened when it stopped working? had you or Brian done anything different? or just working then not working?
another thing to try - do you have a network socket on your laptop? if so, turn off the wifi and plug it in. if it works, its your PC, if it doesnt work its the router / modem
 Obviously its the ghostly spirit that knocked your small vase on the floor the other day...
He has been messing around with the settings on your desktop................
I think it may be the ghost of your old van coming back with a bit of a strop cause you got rid of him..
AND got rid of his old racking!!!!
That really can get a ghosty & ghouly very angry you know???
Guinness   Guinness   Guinness Guinness
I could be wrong though??
maybe mr beer is talking again
:innocent
Andy .switched off WiFi  , plugged in yellow lead .lappy is now using cable ......so  problem with my PC you think ?
Apparently Missus tried to log on this morning  ...no access .. been like it all day .
:innocent
There appears to be a rational explanation to the ghostly vase affair
