Good solid advise, that should be taken into consideration the next time anyone needs to install a TT system. You can't expect miracle's from those short 1.2m x 3/8'' rods. The longer the separate rods the better, and never less than 5/8'' Dia.....always double up on depth before putting a second rod in,as Apache says, deeper holds moisture more(closer to water table),
also remember that if you do need to drive a 2nd rod in to go twice the distance of depth of the deepest rod.
hope that makes sense....
Now just think what you may of got, with coupling another rod on to that 7.4 ohm rod??I done one last week but had to break up a concrete path as nowhere else to put it. I decided to bang a thin rod through the expansion joint in the concrete path to test if I was going to get a decent reading. Banged it in a foot and took reading of 437 ohms then banged it in another 6 inches and it went down to 198 ohms. So broke some concrete then put in the 5/8 rod and got my best reading yet. 7.40 ohms. I was amazed bit then client told me the supply tx was 2 garages away lol.
gas leak from going through the pipe instead of touching it?Now just think what you may of got, with coupling another rod on to that 7.4 ohm rod??
Manator,DEEP EARTH GROUNDINGInteresting reading from a Nebraska company
You sure about Bentonite being un-environmentally friendly?? It's basically only a naturally occurring clay that has conductive properties of holding high levels of moisture for extended periods of time. We've used it extensively, on the Great Man Made River Project in Libya directly over the natural underground reservoirs to ground the pumping stations. That Project had environmental water Engineers crawling over everything.There have been a few experiments over here using Bentonite I also remember some environmental agency guy saying it should not be used on deep rod installations because of the unknown leakage into the water, I am not sure of the location of this information, its just from memory.Substations in this country use both mesh and deep rod, some are very similar to the American set up, but we tend to go one step further.
