I am designing a large car park lighting scheme. I have received lux plots back from a manufacturer and will be installing 56no. Lights on 6m columns with 70w lamps. The lights will be in 8 rows of 6. As the car park is so large I will have a supply feeder pillar with dist. Board. This will feed 3 rows of lighting and barriers, cameras etc and a further 2no. Feeder pillars with dis boards. I am wiring 6 lights on one circuit but wondered what peoples thoughts were. Should I wire each light on a separate circuit with its own NBC or would it be ok to wire 6 lights in each circuit. There will be a 2 way consumer unit in each lighting column so each light can be isolated individually. The only thing is there will be 2no. 2.5mm2 or 4mm2 2 core armoured terminating in the board ad i will be looping in to go to the next light.
