NOZ, did your boiler have an over-run facility though?
from the link Monkey has posted about his boiler I cant see an over-run in the boiler.
NOZ , I think that is the problem, thats NOT AFAIAA his boiler, its a generic diag he has, and it requires the boiler to have a pump control in the boiler.I can just make out that monkey's boiler has a PL & a SL...I was guessing that SL is the trigger and PL is the supply to the pump (inc over run)
i know that now:BlushingTBQH Steps,I thought that he had a boiler that controlled the pump overrun,, I though that he had a boiler similar to the diagram
trying to wire a different type boiler to that diagram would be daft.
this would tie in with it being an oil burner, and the fact it has L + SL terminals,Heat Pac System C Boilers are fitted with Pressure vessel,Grundfoss circulating Pump, ,,,,,,,,
