You must have done new circuits & completing an EIC including relevant testing required & where to find the infomation from the books you should have?The problem i have is i have not done one during training.
And you dont see that as a problem?.... As said contact DNO & arrange for them to remove the service fuse & re-instate when you've done the work, or get them to install an isolator, you could have this & 25mm tails fitted ready for them to connect meter to it, leave isolated do you cu swap & connect new tails dead test installation, turn on isolator complete live testing & cert.I dont have a problem doing it just have a few questions on the safe isolation.
Call DNO ....................... I wouldnt advocate you call the seal fairy.a) How do i replace the tails when the fuse is sealed
Doesnt matter a jot wha the meter is, you must undertake all relevant testing required for the work you ave undertaken..........it's in the books you should haveB) I have a megger MFT1730 which tests do i need to carry out.
Please do not take offence as this is a general observation to all who have taken electrical coursesc) any advice on this would be greatly appriciated
If you dont have the knowledge post your course, I would seek a refnd as the course obviously wasnt up to scratch for the advanced electrical works/testing you are wanting to undertake.
