not really any use for changing a CUProper cable markers ?
i use white or yellow tape around the live phase line
I do not think your being pedantic, you should always consider damage caused by you during erection. However I would not worry various makes of markers have been used for years with no reported side effects.I use a Sharpie to mark T&E and tend to mark both sides. Now then, I've always wondered though does the ink affect the sheath? Might sound pedantic but you're always told about sheaths being damaged by contact with some some insulations and when buried direct in cement without capping...........so why not permanent marker ink?
Well, they need to as locally my mate wants one fitted prior to some CU upgrading and when I do my parents house ditto though I think, fingers crossed that he, my Dad, gets his juice from British Gas now! I have a feeling that BG include for the supply and fitting of the isolator for around theEDF don't do isolators very often. I think i have only ever seen one on a job and i have seen hundreds.
Yes its a 30mA. Consumer unit at the mo is in an open fronted porch high up against the ceiling. New one going in the hall at a comfortable height so I can sit on a stool in front of it and my tea won't get cold!is that a 100mA RCD?then I wouldnt bother having an REC2 fitted,
if its only a 30mA then it needs replacing, but otherwise its not worth the hassle.
I wouldn't bother changing the tails between the meter and the isolator. when the power is off cut the existing tail and fit that into your isolators supply side. Then use 25mm if you want to to feed the CU/RCD, note it on install cert as 25mm supply cable. NIC, Elecsa etc aren't going to be interested as anything up to the isolator is the suppliers responsibilty.Yep, that's the plan! I can switch the stand alone RCD off and leave it "hanging" with the live tails on the other side. Then I can fit the new RCD & enclosure AND the new Wylex REC unit. Was wondering if I should fit some tails to the REC to go into the meter, that we it will all be all new colours on the tails and 25mm sq.Only a stop gap until I fit a new CU.
Cheers
they are only responsible upto and including the meterI wouldn't bother changing the tails between the meter and the isolator. when the power is off cut the existing tail and fit that into your isolators supply side. Then use 25mm if you want to to feed the CU/RCD, note it on install cert as 25mm supply cable. NIC, Elecsa etc aren't going to be interested as anything up to the isolator is the suppliers responsibilty.I work for the sub-contractor that fits Western Power's isolators, although I don't personally install them. I know the guys that do installations, and they use the existing 16mm tails to feed the isolator as WPD deems this to be sufficient. I then have to fit 25mm tails for the next foot to reach the CU, which is a bit of joke really as most main fuses are 60 or 80 Amps.
there is an option to seal REC2's, but there is no requirement. you could easily remove the seal if you wanted to. its not as if you can steal leccy or anything. the seal is probably just to stop you getting at the live sideI've been told by the people doing the isolator install they(WPD) are responsible for the incoming side of the switch, as they seal the cover on the isolator. If I'm wrong then I've been mis-informed.
