Hi folks,
First of all let me explain the situation I find myself in.
I have recently had a gas safe engineer carry out a landlords safety check (CP12 is that what they are still called, I cannot see that reference number on the report any longer?) at my investment property, a one bedroom 2nd/top floor flat in a block of fifteen. He advised me that regulations have changed and he would have to mark the flu on the gas warm air heating unit as not to current standards. He further informed me that I had about a year to bring it up to standard.
The flue vents out vertically through the ceiling and up out onto the flat roof, previous engineers have been satisfied after doing a visual inspection and a smoke test. However the engineer said that the new regulations require the whole length of the flue pipe to be inspected which can't be done because approximately 2 feet is concealed by the flat roof structure. My first thoughts were to have the flue redirected but a hole would have to be cut in the cupboard in which the unit is housed, a ninety degree bend in the flue pipe across the main hallway into the flat to the nearest outside wall. I imagine if it were possible it would be costly and unsightly, the flue pipe would be above head height but below the ceiling. The unit is very old now and my intention was to replace it with a newer version from the same manfacturer with the minimum of fuss, that is disconnect and remove the old one and slide in a new one in it's place, this would appear not to be an option now.
Ok, obviously my next thoughts were a combi boiler so I had my lettings agent send up their gas engineer to give me a quote for a full central heating system. At this point I should mention the flat has concrete floor and brick walls, it would only need four rads, one for the hallway, living room, bedroom and bathroom. There's no space in the kitchen for a rad, it has an electric plynth heater. The gas engineer came back and said that I'd need to consider electric heating because it would be too much work and upheavil to put in rads and pipework because of the concrete floor and also the pipework would have to run around the kitchen in an unsightly position just above the worktops or to be more precise just above the upstands. The kitchen is quite new and smart so I obviously do not want to spoil it. I should also mention that there are fitted wardrobes in the bedroom which would also get in the way of pipework.
So that seems to leave me only with an electric heating system option. Not that I'm averse to this I did not mind it when I lived in a one bedroom flat before with storage heating and I like the low maintenance and no yearly CP12 reqiurement. However there may be a fly in the ointment here as all the electricity meters for the block of fifteen flats are housed in a cupboard on the ground floor (my flat is on the second floor) so I do'nt know how big of a problem that would be if a needed a white meter installing inside the flat? Having said that I am aware that there are now some super efficient electric heaters on the market which may be better than storage heaters that can be wired into 13 amp sockets?
Thanks for reading if you've got this far and any help would be much appreciated.
