Circuit Removal
tymark
Feb 20, 2009
9
I've been asked to remove a Shower feed circuit from a bathroom. there is no EIC or PIR certs available - do i need to leave any paperwork for the job ? Obviously I'll recommend a PIR as they have recently bought the property just wondering if there was any paperwork needed for the removal of a circuit - its not something i've been asked to do before.
Thanks for any Help :)
As far as i know you dont have supply cert as not adding new circuit just removing old cable
Just do it , sometimes I think we get obsessed with all this male-cow-manure about paperwork , its hard enough trying to earn a living as it is without writing a book about it when you get home.
Deke
I agree with all the above. Just take it out no certs needed.
One safety point if the mcb is unused I would remove it and install a blank in its place.
Prevents the owner from adding some flex for a light through a 40amp mcb.
It can be tricky doing an R1+R2 or Ins Res or Zs on a cable thats not there...
and as for writing the details of a circuit breaker that no longer exists..
As said NO need for certs on a removal.. but as GH said MUST be done safely to avoid accidental re-energising of a redundant circuit.
thats what i thought - if there had been an EIC or PIR i would have put a line through the circuit number and added "circuit removed on <date>" or words to that effect. i've put a blank in, removed the mcb (you never know when they will come in handy !) and put a plain label over the shower one. just wanted to check with everyones opinion as strictly speaking its work in a bathroom which is notifiable, but how can you notify if you can't supply certs ?
