- Oct 22, 2010
- 14,620
- 1,170
Good luck with that :SaluteOnce the IET guide is out (due March I think), I'll post the gist of it as it's part of my subscription.
I only fitted two metal domestic ones since it kicked in this year . My first thoughts on the lid hinging upwards cannot be printed here until ................ calming down and giving it more thought ...... gravity prevents you from leaving it open ..although its a PITA having to hold it up while working on it.
I thought they'd gone bust. :CMagnet?
works for me!
then why mention switchgear assemblies if it was all about the size of the cables? Would have made a lot more senseI read it as.....
Anything that could potentially have up to a 25mm2 tail rammed into its terminations "IS Rather Similar".....
Whereas an accessory such as a shower or cooker switch that can only accommodate up to 10mm2 is not!
:Salute
insulating tape?Magnet?
works for me!
The risk of electrification due to metal consumer units was one of the primary considerations for the introduction of plastic units.I have mentioned here before about having to hold up the lid. It could be dangerous for both sparky and users to re-energise a tripped circuit whilst holding onto the installation's metalwork. I suspect that more deaths could be caused in this way than ever occurred by combusting CUs.
Manator, you have lost me, any more clues please? Unless you refer to BS EN 61439-3?
I have scoobed you because you went back and read it.you mean "The above table provides general guidance and is not intended to be an exhaustive list of
inclusions and exclusions."? So an RCD could be in or out of scope, just not listed.
I work in London and have yet to see a TT installCanoeboy said:Ask for it in writing......
(So when they change their minds and you get pulled on assessment)......
Just thinking ahead
What is the difference between an mcb providing overload protection and an mccb providing fault protection? Both are single items of equipment and as such are not assemblies, so can go in their own plastic boxes.That is just not right. There is something about the way you worded that post that makes me think it is a MCB in an adaptable box. Which I agree could be put in a plastic box. However, a purpose built 2 way enclosure is classed a similar assembly IMO.
read the definition of a consumer unit in part 2 of bs7671 and explain how an mccb in an enclosure can be defined as a consumer unit.
I read it as a type-tested assembly of a DP switch and a fuse/mcb/rcd
If you were to buy a metal 2-way box and put an mccb in there. How does that comply with BS EN 61439-3? Unless both the enclosure and the mccb were made by the same manufacturer and were tested as such under that standard. They can't be AFAIK since they do not constitute an assembly and do not come under that standard.
