Theorysparky
Domestic Electrician
- Feb 18, 2008
- 4,232
- 0
You want a better quality of sound ?????/
CLEAN YOUR EARS OUT !!!!!!
Does he live in a caravan sited on a caravan park? If not then its not relevant anyway.He went back to the Naim helpdesk who apparently said that this is the same as is done perfectly safely at caravan parks??
Suppose you're screwed(sorry about the pun) if you use Philips/Crosshead then!!: :coatbut it used to be that he would recommend aligning the screw heads on the terminals; preferably north/south
http://www.russandrews.com/product.asp?lookup=0 [/QUOTE
Never mind what the assessor says, there is a specific reg that forbids simultaneously accessible earthing systems. Have not got book in front of me, but there definitely is a reg for this!!I'd double check with the NIC mate, coz that sounds wrong to me & I was specifically told by my AE during a discussion at my last assessment that you could not have mixed earthing systems accessible!
so, I think that means you could,Aha; "Simultaneously accessible exposed conductive parts shall be connected to the same earthing system individually, in groups or collectively"Soooooo, no way on this planet could you have all different socket outlets with their own earth rod, [i think that this is what has been suggested]
Yes socket outlets on caravan parks each have their own earthing arrangement, but, this is for the socket supplying each caravan. As has been pointed out, each caravan is an installation in its own right, it is not mixing earthing arrangements in an installation.
I am sure that there are more regs that cover this, i just cannot find them right now!!!
john...
Nahhhhh!!!Just like these you mean
