Hi Guys,
Just looking for opinions, I'm on a fairly big new build house , it's one of those jobs that I can leave to go and do other jobs but whenever I return the client, a professional person who thinks electrical work is easy as it's only 2 wires,
as does just about every other trade,
anyhow whenever I return to the job the client has fitted something, outside lights, although only the loop side cos he can't do the first light, outside sockets, internal lights, offering me advice even though I'm over 40 years in the game.My query is ,how would.you guys handle.this.Cheers
My thoughts...
1/ If it is a fairly big new build... that would inevitably involve multiple site visits...
Unless it is a regular good previous customer who you have done multiple jobs for in the past...
Then a clearly specified written schedule of works would have been agreed prior to commencement..
And invoicing / payment terms also agreed..
(This type of work is pretty much impossible to accurately quote.. so allowances for variations have to be considered)
2/ Changes of specification part way through a large job are not uncommon...
Which in principle is not much different to a customer, (or A.N.Other Third Party), doing a little bit of work themselves here and there..
e.g. customer decides that a door is going to swing in the opposite direction.. so light switch has to move to opposite side of door...
Or, wants extra socket outlets / outdoor socket / TV-Data socket / Downlights not pendant.. etc.. etc..
3/ If any changes part way through a job will affect the previously expected costs... then just amend invoices accordingly...
unless the amendments are significantly less than originally specified...
in which case... still charge very near the original amount.. for doing possibly less than originally agreed???!
I understand John's point of view and I kind of agree that the bloke wanting to do some of the install himself is no big deal. Though when it's a new build the building regs are strict with codes the electrics have to comply with.
I would have a word with the home owner and explain the you can only test and certify the work you have done and because he is installing additional fittings those wouldn't be covered under the building regs so it could cause him problems when it comes to sign off.
OP when you say he's trying to give you advice. In which way? Obv he's rubbed you up the wrong way so could it be he's only looking for information. Could you give an example please.
The bottom line is you only have to design, install, test, certify your own work..
If you cannot fully describe the extent of your works covered in the small box on the default certificate..
then add additional page(s)....
It is NOT your problem to fully account for 100% of a whole installation..
Not much difference to a minor works when adding an additional socket to an existing circuit....
where you have no idea about who installed and/or tested, (or not), the full extent of the original circuit,
prior to your additional socket + cable!!!
