I used some several years back and yes it was SF stuff and I was impressed, you just fold the sides up and they clip firmly together and then the lid is as per normal. This stuff was selve adhesive but I put screws in (belt and baces). It was used to run a 10mm at my mates gym for a sunbed and it aint fell apart yet:^OHas anyone ever used coiled mini trunking?is it any good? does it collapse when you try to put the lid on?
i never new it existed until today!!! Blushing Blushing Blushing Blushing
I think its the biggest dollop of doggie Pooh out! :_|Has anyone ever used coiled mini trunking?is it any good? does it collapse when you try to put the lid on?
As with everthing there is good stuff and bad, the stuff I used is in a box and you pull out the length you need and the lid is rolled seperate, the lid bangs on so tight that there is no way it would try and curl back.I think its the biggest dollop of doggie Pooh out! :_| Hate the stuff!
First came across it around 12 or 15 years ago!!!
never liked it... still hate it...
avoid it like the plague! X(
If you have a roll several metres long.
and you want a couple of meters length...
Trying to measure & cut it to length you waste so much time & trunking
just quicker & easier with ridged stuff.
I have had some where the lid keeps trying to curl back off the sides as you try & clip it into place! :|
So for my jobs its a big NO NO!
I honestly can't remember.....As with everthing there is good stuff and bad, the stuff I used is in a box and you pull out the length you need and the lid is rolled seperate, the lid bangs on so tight that there is no way it would try and curl back.I've only tried the SF stuff though, but for long runs its quick and easy and tidy as there are no joints easy to keep in the van.
Special what stuff did you use ?
Applaud SmileyApplaud SmileyApplaud SmileyApplaud Smileythats what the missus said isnt it
Blushingthats what the missus said isnt it about her a**e when she looks in the mirror
wow a 7.5meter van! Bet that's fun to park........im in 2 minds now!ive just bought 15M of ridgid stuff and hat to cut it in half to get it in the van!
i might try and get some cheap!
