College paper works
L Plate
May 22, 2009
250
Hello again to all,
I need help again regarding my college paper works,
last week i installed a very simple single light circuit in a cubicle in college workshop, i test the continiuty by using the Fluxe tester, and i fully understand on how to do the continiuty test , the next job is adding another switch to become a 2way switch alternative, one of the question is >> HOW DOES THE TWO WAY SWITCHING IN THIS LIGHTING CIRCUIT AFFECT TESTING?
the other one is all about R1 and R2
as far as i understand that R1 is all about to check the live side ? am i right?
and R2 is all about to check the cpc ? not really sure ,
is there any deeper explanatin about R1 and R2 base from the onsite guide pls? haven't got any yet at themoment .
again thank you for your help
have a nice day all
Hello again to all,
You have to operate all switches to prove their contiuous and continuity is there throughout.
OK
It checks the continuity of the Line conductor, Yes.
It checks the continuity of the cpc, Yes.
By Checking the R1 & R2 of the circuit and operating all switches, you are also checking the Polarity is correct too.
You're Welcome.
have a nice day all
You too. :D
Hello again to all,
last week i installed a very simple single light circuit in a cubicle in college workshop, i test the continiuty by using the Fluxe tester, and i fully understand on how to do the continiuty test , You have to operate all switches to prove their contiuous and continuity is there throughout.
OK
You're Welcome.
You too. :D
THANKS A LOT ADMIN THAT WAS THUNDER AND LIGHTNING REPLY....I O U A Guiness Drink
