Would the isolator go just prior to the consumer unit i.e. between the cut-out and consumer unit? What exactly do they look like / where can you get them?Paul b b is incorrect; the cut-out is the property of the DNO, and you are committing an offence by interfering with it.If there is no means of isolation, then the proceedure, as Manator says, is to contact DNO to arrange disconnection. This can be a good time to install an isolator for future use.
KME
I haven't m4tty. Do they charge for the privilege? How do you get access to the cut-out?In the real world I believe most sparks would pull the mainfuse. Just be careful mate. Not the correct legal way to do it, but you gotta earn a wage. Have you tried contacting dno lately?
Here are the ones that I have - These are also used by the LEB and DNO.Would the isolator go just prior to the consumer unit i.e. between the cut-out and consumer unit? What exactly do they look like / where can you get them?
Aye, it looks like it. What would that mean? Does it have anything to do with the flat above ours?[if you have 2 fuses is one of them on the incoming neutral ?????
Aye, it looks like it. What would that mean? Does it have anything to do with the flat above ours?if you have 2 fuses is one of them on the incoming neutral ?????
It stands a chance, are there meter tails connected to it leading up to the flat above ??Aye, it looks like it. What would that mean? Does it have anything to do with the flat above ours?
So far I haven't had to go near the electrical cut-out. It's been explained to me previously how to kill the supply but as i've never had to do it (or seen it done) I just wanted to be clear about exactly what the process entails.Don't take this the wrong way Damien, but I see you are registered as an NICEIC Domestic Installer and your questions are fairly basic for that disipline . Has it not occurred to you before how to kill the supply ? There is a previous thread devoted to this if you want to take a look.
Don't take the hump at this ,stay with us , you'll get good advice from the guys .
It does seem so. There are 2 entry points in the wall - 1 to my CU and it would seem the other is for the flat above.It stands a chance, are there meter tails connected to it leading up to the flat above ??
