1.Where is the best position to locate a cooker outlet for a built in oven.
2. The OSG states that a 30 or 32 A circuit is ok for cookers rating up to 15kw (which is a pretty high load) the circuit no doubt accounted for by diversity.
However does this still hold for induction hobs e.g 7.2 kw which I am told on start up come on full load!. According to the OSG an oven of up to another 7.5 kw could also be connected to the same supply and depending on cable ref method could be wired in 4mm. Does not make that much sense.
