CU change, cable entery
The CU is in the down stairs loo !! and above the toilet, bottom of CU is 7ft 6" so I could move it down but would have to go across the wall a bit, due to boxing for waste pipe, but in doing that it would puts it a bit closer to the sink, all be it still 4-5ft above.
So might just keep it where it was to make the job a bit easier.
Lyngarth
nothing wrong with its location. risk assessment would tell you whether its in a good place or not. it probably is fine, and could probably be moved closer if necessary
the only issue i would see from a H&S point of view would be how would u excess it safely.
it is not ideal to stand on the toliet seat every time you need to excess the CU...
