Jonnyboy 68
- Apr 25, 2010
- 26
- 0
On CU installations, I like to use a some jumbo trunking or similar to protect the cables where they break through the ceiling to where they enter the CU. I do this primarily to protect the cable from damage etc but also it gives a very professional and neat look to the job. I try to do this regardless of where the CU is situated. However, I have noticed that this is not the case in a lot of CU's I've seen and the cables are just clipped direct and run in through the top of the CU... Is this just me being too 'militaryfied'... It seems obvious to me that these cables should be protected like in the rest of the install.... What are your thoughts on this ?? Out of interest ..What methods do you guys use on your installs ?? ...
For my elecsa assessment, I'll be using a CU as example so I'm lookin for a bit of bull**** baffles brains material !!!!!
