^^ So do seriously consider an EICR to assess the installation - you have provided enough information to suggest this needs to be done.
It is top of my priorities for tomorrow. Then, hopefully, I can move forward with this and get the electrics made safe.^^ So do seriously consider an EICR to assess the installation - you have provided enough information to suggest this needs to be done.
The more I read the more I’m inclined to agree with the Doc, I suspect that the OP has said he’ll require three water heaters which he’ll provide, the builder had relayed this to the spark who, wrongly assumed it would be three small water heaters- why given it’s a tea room? Then A N Other (read as Builder or his plumber) has connected. The electrician is almost innocent. However what it does highlight is the importance of understanding the clients needs prior to proceeding with any works regardless of your trade or skill set. If you don’t see what the client sees then you will fall foul!
im thinking the same. were the heaters provided and on-site before the place was wired?
