Riggy
Anyone used any?
Anything I need to know?
Do they use standard tubes?
Thanks in advance.
Thanks in advance.
Depends on the dimming wiring. Some just work in a similar fashion to incandescants and dimmers, some have a seperate control wire for dimming.Same application. I assume they are no different to install than a standard corrosion resistant fitting?
So you have a Live and a Dimmed Live - am I undestanding you right?Depends on the dimming wiring. Some just work in a similar fashion to incandescants and dimmers, some have a seperate control wire for dimming.
No. You'd have a 230V feed looped though all the fittings. This is simply on\off as on a normal lighting circuit. You then have a low voltage pair looped through all the fittings which provides 0-10V (0V full, 10V dim) from the controller.So you have a Live and a Dimmed Live - am I undestanding you right?
Local to me in North Cumbria.Yes they normally have a 0-10v dimmer ...Where is your chicken job ?
