Hi there,
I am diy'ing in a bedroom and a corridor and wanted to see if I can figure out how to attach a lot of wires from wallamps & other dimmers etc..Currently the wall lights do not work.
I guess I may have to call an electrician for this, but any help is greatly appreciated!!
Some explanations to the conondrum since inside of the dimmer switch back box (plastic, the one I am fixing) there are 14 small wires from 5 cables:
- My dimmer switch is standard 1-way, with 3 ports: C, L1 and L2
- There was one roof lamp in the room from before (removed with wires isolated in box).
- 2 cables with 6 wires come from 2 wall lights: blue, brown and neutral.
- 1 cable with 3 wires come from another socket: blue, brown and neutral. The other socket should work independent of this one being switched on/off.
- 1 cable with 3 wires come from ??: This one is old and has White, Blue and Red wires. Could this be to roof lamp or Electrity incomming?
- 1 cable with 2 wires come from ??: This one is old and has Black and Red wires. Or this may be to roof lamp or Electricity incomming?
From before all of the blue wires (and one black) were somehow bundled together behind the switch. There were a few red/brown / one white inside the dimmer switch, but then again this did not work..so perhaps pointless information..
Thanks a lot for help, and excuse my ignorance!
Rgds, Henrik
Rgds, Henrik
