Dimmer switch help.
Petebham
Jan 29, 2017
2
Telford
Hi all - complete newbie question.
i want to replace a standard rocker switch with a dimmer in the hallway.
the rocker has 4 wires in it - and can be controlled from 2 other switches... what kind of dimmer switch do i need?  I had a spare dimmer which is onely a 1gang 1way - guessing i cant use that.  So do i just need to order a standard 3 way?
the wires are yellow and blue
yellow.    Blue
yellow.  Blue
thanks in advance
the rocker has 4 wires in it - and can be controlled from 2 other switches... what kind of dimmer switch do i need?  I had a spare dimmer which is onely a 1gang 1way - guessing i cant use that.  So do i just need to order a standard 2 way?  Intermediate?
yellow.    Blue
yellow.  Blue
thanks in advance
Good luck, dimmers are only available in 1 way and 2 way. I have never seen an intermediate/3 way dimmer. As Andy  says, you will need to fit a 2 way dimmer to one of the other 2 switch positions.
