Diplomat Hob
hectorthetester
Jan 12, 2009
10
I was looking at a fault with a Diplomat APL 1304 for a family relative.Problem is appliance is tripping mcb at consumer unit when a specific ring is switched on.Any way i dismantled the appliance to visually examine the hob ring and found no apparent visual damage ie broken/damaged element.I disconnected the wires from the stat to the ring and re energised the supply.When i turned on the control knob to the maximum position at the first attempt it immediately tripped the mcb (i then thought the control stat/switch was the culprit).However i re energised the appliance again and again set the control knob to the maximum position-this time the mcb did not disconnect.My suspicion is on the hob ring?
Any suggestions much appreciated.
