Directory list of BS British Standard/Standards Numbers & More on Books International
a1
Forum Founder
Feb 6, 2008
10,184
-1
Hi All,
I have put together this list of UK, BS Booksm BS Numbers, ISBN Numbers, Dates Published, Other 'Known as', Descritptors, Cross References & Replaces. for your Information.
I know there are several BS Books that I have listed that you may not need - But they are there for whoever does need them.
HTH - Admin.
Key:
BS = British Standards (Not what you were probably thinking, lol).
BS 5834-3 Surface boxes, guards and underground chambers for gas and waters purposes. Specification for large surface boxes.
ISBN Number: 0 580 14306 6.
Published: 31/10/1985.
Also Known as: BS5834-3:1985
DESCRIPTORS: Surface boxes, Protective barriers, Gas valves, Stop valves, Water supply, Water supply and waste systems (buildings), Gas supply, Water mains, Pipelines, Cast-iron, Steels, Reinforced concrete, Design, Dimensions, Protective coatings, Loading, Classification systems, Marking, Type testing, Grades (quality)
CROSS REFERENCES:BS 12, BS 146:part 2, BS 497:part 1, BS 729, BS 750, BS 882, BS 1047, BS 1449, BS 1452, BS 1610, BS 2569:part 1, BS 2789, BS 3148, BS 3416, BS 3892:part 1, BS 3892:part 2, BS 4027, BS 4147, BS 4164, BS 4190, BS 4360, BS 4449, BS 4461, BS 4482, BS 4483, BS 5075:part 1, BS 5328, BS 5834:part 2
REPLACES: N/A
BS 5834-4 Surface boxes, guards and underground chambers for gas and waters purposes. Specification for preformed chambers.
ISBN Number: 0 580 17416 6.
Published: 29/09/1989.
Also Known as: BS5834-4:1989
DESCRIPTORS: Surface boxes, Underground, Construction systems parts, Prefabricated parts, Glass fibres, Plastics, Reinforced materials, Reinforced concrete, Grades (quality), Loading, Marking, Chemical composition, Dimensions, Thickness, Holes, Slots, Slabs, Strength of materials, Sampling methods, Quality control, Stiffness, Mechanical testing, Testing conditions, Crushing tests, Deflection tests, Joints
CROSS REFERENCES: BS 12, BS 146:part 2, BS 882, BS 957:part 2, BS 1047, BS 1610:part 1, BS 1610:part 2, BS 1881:part 108, BS 1881:part 111, BS 1881:part 116, BS 1881:part 120, BS 3148, BS 3396, BS 3496, BS 3532, BS 3691, BS 3749, BS 3892:part 1, BS 3892:part 2, BS 4027, BS 4449, BS 4461, BS 4482, BS 4483, BS 5075, BS 5834:part 2, BS 5834:part 3, BS 6588, BS 6699, Road Vehicles (Construction) Regulations
REPLACES: N/A
BS 5835-1 Recommendations for testing of aggregates. Compactibility test for graded aggregates.
ISBN Number: 0 580 11256 X.
Published: 30/06/1980.
Also Known as: BS5835-1:1980
DESCRIPTORS: Aggregates, Compaction tests, Mechanical testing, Road bases, Pavements (roads), Test equipment, Mathematical calculations, Charts, Moisture, Moisture measurement, Specimen preparation, Density measurement, Water-absorption tests
CROSS REFERENCES: BS 812:part 1, BS 812:part 2, BS 892, BS 1377, BS 2787
REPLACES:
BS 5836 Guide to CAMAC: organization of multi-crate systems: specification of the Branch-highway and CAMAC crate controller Type A1.
ISBN Number: 0 580 11140 7.
Published: 29/02/1980.
Also Known as: BS5836:1980
DESCRIPTORS: Data transmission control procedures, Interfaces (data processing), Instruments, Modules, Nuclear technology, Computerized control, Data handling, Electronic equipment and components
CROSS REFERENCES: BS 5554
REPLACES: N/A
INTERNATIONAL EQUIVULENT: IEC 60552:1977
BS 5837 Trees in relation to construction. Recommendations.
ISBN Number: 0 580 46418 0.
Published: 21/09/2005.
Also Known as: BS5837:2005
DESCRIPTORS: Trees (plants), Landscaping, Physical planning, Building sites, Buildings, Foundations, Construction works, Legislation, Surveys, Damage, Planning, Fences, Planting, Tree surgery, Arboriculture
CROSS REFERENCES: BS 3998:1989, BS 4428:1989, BS EN ISO 11091:1999, PAS 100:2005, Town and Country Planning Act 1990, Forestry Act 1967, Wildlife and Countryside Act 1981, Conservation (Natural Habitats etc.) Regulations 1994, Countryside and Rights of Way Act 2000, Hedgerows Regulations 1997, Construction (Design and Management) Regulations (CDM) 1994, Environment Act 1994, NHBC Standards. Chapter 4.2:1999, BS 8206-2:1992
REPLACES: BS 5837:1991
BS 5838-1 Specification for dry packaged cementitious mixes. Prepacked concrete mixes.
ISBN Number: 0 580 11145 8.
Also Known as: BS5838-1:1980
DESCRIPTORS: Concretes, Cement and concrete technology, Ready-mixed materials, Composition, Marking, Packages, Aggregates, Sampling methods, Specimen preparation, Workability, Compressive strength
CROSS REFERENCES: BS 12, BS 146, BS 812:part 2, BS 882, 1201, BS 1047, BS 1881:part 2, BS 1881:part 3, BS 1881:part 4, BS 3177, BS 3797, BS 5075:part 1, BS 5075:part 2
REPLACES: N/A
BS 5839-1 Fire detection and fire alarm systems for buildings. Code of practice for system design, installation, commissioning and maintenance.
ISBN Number: 0 580 40376 9.
Published: 15/10/2002.
Also Known as: BS5839-1:2002
DESCRIPTORS: Fire alarms, Fire detectors, Alarm systems, Fire safety in buildings, Fire safety, Buildings, Design, Installation, Commissioning, Maintenance, Planning, Smoke detectors, Means of escape from fire in buildings
CROSS REFERENCES: BS 476, BS 4678-4, BS 5588, BS 5839-8:1998, BS 5839-9, BS 5979:2000, BS 7273, BS 7629, BS 7671, BS 7846, BS 8434-1, BS 8434-2, BS EN 54-2, BS EN 54-3, BS EN 54-4, BS EN 54-5, BS EN 54-7, BS EN 54-10, BS EN 54-11, BS EN 54-12, BS EN 50086, BS EN 50200, BS EN 50281-1-2, BS EN 60079-14, BS EN 60702-1, IEC 60702-1, BS EN 60702-2, IEC 60702-2, BS EN 61558, BS EN ISO 13943, LPS 1257, Health Technical Memorandum 82, Alarm and detection systems, BS 5306-2, BS 5839-6, BS 6266, BS 6387, BS 6651:1999, BS 7807, BS 7974, BS EN 50131-1, BS EN 60651, BS EN ISO 9000, IEC 60331, PD 7974-4, Health and Safety (Safety Signs and Signals) Regulations 1996, Fire Precautions Act 1971
REPLACES: BS 5839-1:1988
BS 5839-3 Fire detection and alarm systems for buildings. Specification for automatic release mechanisms for certain fire protection equipment.
ISBN Number: 978 0 580 59885 2.
Published: 29/04/1988.
Also Known as: BS5839-3:1988
DESCRIPTORS: Fire alarms, Fire detectors, Alarm systems, Fire safety in buildings, Fire safety, Buildings, Smoke detectors, Automatic control systems, Fire doors, Fire spread prevention, Fire dampers, Manually-operated devices, Voltage, Electrically-operated devices, Electrical safety, Hydraulically-operated devices, Marking, Test specimens, Specimen preparation, Test equipment, Testing conditions, Damp-heat tests, Environmental testing, Thermal testing, Cold tests, Sulfur dioxide, Corrosion tests, Durability, Mechanical testing, Impact testing, Vibration testing, Pressure testing, Hydraulic tests, Performance testing, Release mechanisms, Electromagnetically-operated devices, Electromechanical devices, Type testing, Electrical insulation, Electrical resistance, Endurance testing
CROSS REFERENCES: BS 302:part 2, BS 2011:part 1.1, BS 2011:part 2.1A, BS 2011:part 2.1Ca, BS 2011:part 2.1Fc, BS 2011:part 2.1Kc, BS 2011:Section 4.1, BS 3955, BS 4575:part 1, BS 5345, BS 5490, BS 5750, BS 5839:part 1, BS 6459, BS EN 1155
REPLACES: N/A
BS 5839-5 Fire detection and alarm systems for buildings. Specification for optical beam smoke detectors.
ISBN Number: 0 580 16252 4.
Published: 31/03/1988.
Also Known as: BS5839-5:1988
DESCRIPTORS: Fire alarms, Fire detectors, Alarm systems, Fire safety in buildings, Fire safety, Buildings, Optical instruments, Smoke detectors, Detectors, Sensitivity, Performance testing, Fire tests, Warning devices, Response time, Electrical testing, Turbulence, Reproducibility, Marking, Specimen preparation, Test equipment, Testing conditions, Tolerances (measurement), Environmental testing, Performance, Impact testing, Type testing, Voltage fluctuations, Mechanical testing, Tracking tests
CROSS REFERENCES: BS 161, BS 1853:part 2, BS 2011:part 1.1, BS 2011:part 2.1A, BS 2011:part 2.1B, BS 2011:part 2.1Ca, BS 2011:part 2.1Fc, BS 2011:part 2.1Kc, BS 3955, BS 4803, BS 5445:part 9, BS 5446:part 1, BS 5750, BS 5839:part 1, BS 6073, BS 6667:part 2, BS 6667:part 3, IEC 801-4
REPLACES: N/A
BS 5839-6 Fire detection and fire alarm systems for buildings. Code of practice for the design, installation and maintenance of fire detection and fire alarm systems in dwellings.
ISBN Number: 0 580 44100 8.
Published: 15/09/2004.
Also Known as: BS5839-6:2004
DESCRIPTORS:Fire alarms, Fire detectors, Alarm systems, Fire safety in buildings, Fire safety, Buildings, Domestic facilities, Domestic, Design, Installation, Maintenance, Fire risks, Smoke detectors, Grades (quality), Position, Audibility, Hearing defects, Frequencies, Electric wiring systems, Control equipment, Communication equipment, Remote control systems, Radio links, Instructions for use, Indicator lights, Marking, Risk assessment
CROSS REFERENCES: BS 476, BS 3955:1986, BS 5446-1:2000, BS 5446-2, BS 5446-3, BS 5588-1:1990, BS 5839-1:2002, BS 5979, BS 7671, BS EN 54-2, BS EN 54-3, BS EN 54-4, BS EN 54-5, BS EN 54-7, BS EN 54-11, BS EN 54-12, BS EN ISO 13943, LPS 1265:Issue 1.0, BS 7860:1996, BS EN 50291:2001, BS EN 50131-1:1997
REPLACES: BS 5839-6:1995
BS 5839-8 Fire detection and fire alarm systems for buildings. Code of practice for the design, installation and servicing of voice alarm systems.
ISBN Number: 0 580 29509 5.
Published: 15/02/1998.
Also Known as: BS5839-8:1998
DESCRIPTORS: Fire alarms, Fire detectors, Alarm systems, Fire safety in buildings, Fire safety, Buildings, Speech transmission systems, Safety measures, Design, Installation, Maintenance, Planning, Messages, Information exchange, Circuits, Interfaces, Loudspeakers, Automatic, Defects, Computer programs, Amplifiers, Microphones, Languages, Audibility, Control equipment, Classification systems, Access, Signal devices, Visual signals, Colour, Flashing lights, Life (durability), Position, Electric power systems, Electric cables, Electric wiring systems, Interference suppression, Inspection, Commissioning, Conformity, Noise (environmental), Mathematical calculations
CROSS REFERENCES: BS 6651:1992, BS 7827:1996, 89/336/EEC, 92/31/EEC, Fire Code Alarm and Detection Systems. Health Technical Memorandum 82, BS 1635:1990, BS 5330:1976, BS 5588:part 11:1997, BS 5839:part 1:1988, BS 5839:part 4:1988, BS 6207:part 1:1995, BS 6207:part 2:1995, BS 6259:1997, BS 7443:1991, BS 7629:part 1:1997, BS 7629:part 2:1997, BS 7671:1992, BS 7807:1995, BS EN 60268-16, BS EN 60529:1992, BS EN 60651:1994
REPLACES: N/A
BS 5839-9 Fire detection and alarm systems for buildings. Code of practice for the design, installation, commissioning and maintenance of emergency voice communication systems.
ISBN Number: 0 580 41138 9.
Published: 10/02/2003.
Also Known as: BS5839-9:2003
DESCRIPTORS: Fire alarms, Fire detectors, Alarm systems, Fire safety in buildings, Fire safety, Buildings, Speech transmission systems, Emergency equipment, Design, Installation, Maintenance
CROSS REFERENCES: BS 5588-8:1999, BS 5839-8, BS 7807, BS 7846, BS 5499-1, BS 5588-5, BS 5588-8, BS 5588-10, BS 5588-11, BS 5839-1:2002, BS 7671, BS EN 54-2:1998, BS EN 54-4:1998, BS EN 60529, BS EN 60651, IEC 60651, BS EN 60702-1, IEC 60702-1, BS EN 60702-2, IEC 60702-2
REPLACES: N/A
BS 5841-3 Photographic flash equipment. Specification for electronic single-flash equipment.
ISBN Number: 0 580 13843 7.
Published: 31/08/1984.
Also Known as: BS5841-3:1984
DESCRIPTORS: Photographic equipment, Photographic lighting equipment, Flash equipment, Electronic flash equipment, Instructions for use, Marking, Dimensions, Performance testing, Labels, Electric contacts, Coaxial, Electric plugs, Electric sockets
CROSS REFERENCES: BS 397:part 1, BS 397:part 2, BS 1363, BS 1380:part 3, BS 3205, BS 5841:part 6, BS 5841:part 7, BS 5841:part 10, ISO 518, IEC 491
REPLACES: BS 3205:1969
BS 5842 Specification for thermoplastic hose assemblies for dock, road and tanker use.
ISBN Number: 0 580 11429 5.
Published: 29/08/1980.
Also Known as: BS5842:1980
DESCRIPTORS: Thermoplastic polymers, Flexible pipes, Pipes, Wires, Reinforced materials, Stainless steels, Polypropylene, Dimensions, Hose connectors, Hydrostatic pressure, Pressure testing, Chemical-resistance tests, Electrical conductance, Marking, Low-pressure tests, Petroleum products, Docks, Road tankers, Petroleum technology, Railway wagons, Loading and unloading devices
CROSS REFERENCES: BS 1554, BS 2464, BS 3592:part 1, BS 3592:part 2, BS 5173:part 2, BS 5173:part 3, BS 5173:part 4
REPLACES: N/A
BS 5849 Method of expression of performance of air quality infra-red analysers.
ISBN Number: 0 580 11111 3.
Published: 31/01/1980.
Also Known as: BS5849:1980
DESCRIPTORS: Gas analyzers, Air, Infrared radiation, Performance, Electronic equipment and components, Definitions, Environment (working), Ratings, Tolerances (measurement), Verification, Performance testing, Errors, Accuracy, Precision, Air pollution
CROSS REFERENCES: BS 3586, BS 4743, BS 4889
REPLACES: N/A
INTERNATIONAL EQUIVULENT: IEC 60528:1975
BS 585-1 Wood stairs. Specification for stairs with closed risers for domestic use, including straight and winder flights and quarter or half landings.
ISBN Number: 0 580 16566 3.
Published: 30/06/1989.
Also Known as: BS585-1:1989
DESCRIPTORS: Stairs, Wood, Structural timber, Domestic, Interior stairs, Straight-flight stairs, Flights (stairs), Curved, Landings, Size, Dimensions, Adhesives, Treads (stairs), Risers, Steps (stairs), Adhesive-bonded joints, Strings (stairs), Newel posts, Fixing, Assembling, Balustrades, Hand-rails, Design, Architectural design, Structural design, Design calculations, Classification systems, Designations
CROSS REFERENCES: BS 585:part 2, BS 1186:part 1, BS 1186:part 2, BS 1204:part 1, BS 4071, BS 4471, BS 5395:part 1, BS 5578:part 1, BS 6100:Section 1.0, BS 6100:Subsection 1.3.4, BS 6100:Subsection 1.5.1, BS 6100:part 4, BS 6180, BS 6566, EN 204
REPLACES: BS 585:part 1:1984
BS 585-2 Wood stairs. Specification for performance requirements for domestic stairs constructed of wood-based materials.
ISBN Number: 0 580 14298 1.
Published: 31/01/1985.
Also Known as: BS585-2:1985
DESCRIPTORS: Stairs, Straight-flight stairs, Wood, Domestic facilities, Landings, Steps (stairs), Treads (stairs), Strings (stairs), Risers, Nosings, Flights (stairs), Balustrades, Hand-rails, Size, Deflection tests, Performance testing, Type testing, Mechanical testing, Testing conditions, Impact testing, Static loading, Deformation, Blockboards, Lamin boards, Dimensions, Grades (quality), Moisture
CROSS REFERENCES: BS 449, BS 585:part 1, BS 1142:part 2, BS 1186:part 1, BS 1186:part 2, BS 1204:part 1, BS 4071, BS 5268:part 2, BS 5395:part 1, BS 5578:part 1, BS 5669, BS 6100:part 4, BS 6180, BS 6399:part 1, BS 6566:part 1, BS 6566:part 2, BS 6566:part 3, BS 6566:part 4, BS 6566:part 5, BS 6566:part 6, BS 6566:part 7, BS 6566:part 8, DD 74
REPLACES: N/A
BS 5852 Methods of test for assessment of the ignitability of upholstered seating by smouldering and flaming ignition sources.
ISBN Number: 0 580 47926 9.
Published: 31/03/2006.
Also Known as: BS5852:2006
DESCRIPTORS: Furniture, Upholstered furniture, Seating, Chair covers, Furnishing fabrics, Cushions, Paddings, Fire tests, Ignitability, Ignition cribs, Test specimens, Specimen preparation, Test equipment, Testing conditions, Dimensions, Chairs, Trading standards, TSS
CROSS REFERENCES: BS 3016, BS 4250:part 1, BS 6807, BS 7176, BS EN 1021-1, BS EN 1021-2, Health and Safety at Work etc. Act 1974, HSE Regulations on the Control of Substances Hazardous to Health, Furniture and Furnishings (Fire) (Safety) Regulations 1988
REPLACES: BS 5852-1:1979 BS 5852-2:1982 ** NOTE ** Replaces BS 5852-1:1979 and BS 5852-2:1982 which remain current as they are cited in legislation.
BS 5852-1 Fire tests for furniture. Methods of test for the ignitability by smokers' materials of upholstered composites for seating.
ISBN Number: 0 580 11106 7.
Published: 30/11/1979.
Also Known as: BS5852-1:1979
DESCRIPTORS: Fire tests, Physical testing, Furniture, Ignitability, Seating, Furnishing fabrics, Paddings, Cigarettes, Matches, Smokers lighters, Combustion, Upholstered furniture, Chair covers, Cushions, Trading standards, TSS
CROSS REFERENCES: BS 3016, BS 4250, BS 5852:part 2
REPLACED BY:BS 5852:1990 ** NOTE ** Replaced by BS 5852:1990 but remains current as it is cited in legislation. Was withdrawn but has been reinstated.
BS 5852-2 Fire tests for furniture. Methods of test for the ignitability of upholstered composites for seating by flaming sources.
ISBN Number: 0 580 12842 3.
Published: 31/08/1982.
Also Known as: BS5852-2:1982
DESCRIPTORS: Fire tests, Physical testing, Furniture, Ignitability, Upholstered furniture, Furnishing fabrics, Paddings, Combustion, Ignition cribs, Seating, Flames, Chair covers, Cushions, Wood, Dimensions, Weight (mass), Trading standards, TSS
CROSS REFERENCES: BS 3016, BS 4250, BS 5852:part 1
REPLACED BY: BS 5852:1990 ** NOTE ** Replaced by BS 5852:1990 but remains current as it is cited in legislation. Was withdrawn but has been reinstated.
Yes 'he' can. He can't put 13 digits that haven't come out yet. lol.
