Bronek536
Hi guys.
Just reflecting on the reasons for disconnecting of main protecting bonding conductor when carrying out continuity. As far as I understand it is to avoid parallel earth paths and effects on test readings. However in my dwelling, as I pick any conductor from MET and measure using Test method 2(wandering lead) I get continuity to pretty much every metal conductive part in my house(taps, kitchen sink, pipes gas and water, extraneous and exposed conductive parts). I guess it is a pretty good equipotential zone created. My question is in the above situation would you still disconnect bonding for continuity measurement(not even knowing if this is for water, gas or metal structure bonding because you get reading on all anyway) and if so then why? And finally, is there a way of determining which bonding conductor bonds what if values taken are all the same (I presume caused by parallel paths)?
Bronislaw
Bronislaw
