With rising electricity costs i'm thinking of self installing solar which for a 6KW 16 panel system, i'm estimating £5k cost and possibly a 5-6 year return on investment
Annual use is approx 7000 KWh, south facing roof with room for 16+ panels
Installation/wiring of the panels looks straight forward, and being a spark i can install the inverter/isolators/CU as necessary in the garage
However i'm not MCS certified so could i
1. Connect it to the mains, if not how could i use the generated solar power for the house? (i'm not planning on using batteries as the return on investment is poor)
2. Export any unused power to the grid without MCS certs and get paid?
3. If i can export to the grid, being a 6KW system i presume the easiest option is to put a limiter in place to limit the export to 4KW but then i wouldnt be able to make full use of the 6KW for the house?
Estimated returns using the calculator from https://great-home.co.uk/solar-export-guarantee-seg-calculator/
