Scott Nichol
- Jan 24, 2016
- 2
- 0
H lads
Picking some brain matter if possible
DP Switches at DNO Serving Consumer unit
1:- What is the recommended life span of these isolators as the screws never get checked for tightness, example on an EICR.
2:- PME System - seeing this more regular. Tails from meter to DP 16mm then 25mm out to consumer
(me personal should be same from meter to consumer.)
These companies who fit these DP I Know for certain do not check the fuses so in theory the cable is undersized in some issues- so
is their any sites, where I Can get this info.
(reason why COW on site has pulled few houses - I have been trying to get an answer form these companies but it is a waste of time)
any thoughts Lads
Discuss
cheers
any thoughts Lads
Discuss
cheers
