DNO
r&s
Jul 18, 2009
15
Hi im just starting out on my own and im having no luck findind out the right phone numbers for the supply parameters or getting the fuse pulled. im going to be joining niceic so ive started using there lay out certificates, i know this is a stuid question but what does the Uo stand for, im based in essex
- Uo is voltage between phase and neutral
- U is voltage between phases
---------- Post Auto-Merged at 19:07 ---------- Previous post was made at 19:06 ----------
So on our domestic single phase ... u is n/a uo is 230v
page 36 big red book-
U- voltage between lines (phase, live, tingly wire,etc)
Uo-nominal a.c rms line voltage to earth (earth, neutral)
all single phase systems are 230v, U not applicable, and all 3 phase systems are 400v between phases (U) and 230v to earth (Uo)
Tis all in the big red bible. old testement near the front
Do you's find out by asking or do you just test
are you sure your competent to carry out electrical work? some of your questions are very basic. also, youve been here since 2009 so id assume youve read a fair few threads. which would answer your DNO question & everything else
