kevandali
Hi All
First time on here so shall try and be as detailed as possible.
I have a shed that has a 18 metre run of armour cabled 4mm cable.
I have a distribution box for the shed that contains an 25 amp RCD and two mcb's, one for sockets (16amp), one for lights (6amp).
I am unsure what to use to supply the distribution box for the shed?
The shed will possibly have a computer plugged in and a fridge freezer and I will occasionally use a drill but thats about it.
I was unsure if I needed an RCD to supply the distribution box or simply a correctly rated mob as the shed electrics will be protected by the RCD in the distribution box.
Hope this is clear.
Thanks in advance for the help. (will try and add pics, hopefully)
Kev
Hope this is clear.
Kev
