door open sounder
maccarooni
Jul 13, 2008
339
Have been asked to wire a sounder in to a door entry system.
The door has a press button release inside and a fob swipe on the out.
what and how would be the best way to wire a sounder in to activate if the door is left open. There is a spring return to close the door but someone keeps propping something in front of it.
Many thanks
Macca
Have been asked to wire a sounder in to a door entry system.The door has a press button release inside and a fob swipe on the out.
Many thanks
Macca
Have been asked to do a similar thing, have used a timer and sounder so when the door is opened a door switch starts a timer so that when it reaches a preset time the sounder is activated until the door is closed and timer is reset.
Thanks for the reply Sept,
What type of timer and sounder did you use?
Macca
Info on this would be appreciated
Macca
