Double Immersion Help Please
sprocketflup
BDSM SUB & SWAGFAG™
Nov 11, 2010
2,659
16
Wonderland
Hi, got a customer with an all electric house, no boiler for hot water, just 2 immersion heaters in a cylinder, each controlled by a switch.
She wants to run them through a timer so she can have a tank of water ready for mornings etc, am I right in thinking that a 2 channel time clock will accomplish this? i.e. run the top immersion from 'heating' and bottom from 'hot water' ?
cheers
If he has an all electric house then surely he has economy 7 or 10?  if not then he SHOULD have.
that will provide you with cheap rate overnight specifically for heating storage heaters and giving a cheap tank of hot water.
The answer for how to wire the immersion heaters is different depending on whether he has economy 7 or not.
A normal "central heating" programmer will NOT run the 3KW load of an immersion heater, at least not any that I have seen, they are for switching small loads for the central heating controls.
