Lets not , I'm already spouting a load of of old tosh through not reading the OP properly.Facts as I see,2 * twin and earth 2.5mm
In a conduit/pipe buried 2ft under the surface, to provide power to a shed, I assune from this it is not likely to be subject to a plough anytime soon.
Whats the problem?
Lets move onto the earthing type
we should probably actually cable tie the T&E to a copper water pipe feeding the garage!Lets not , I'm already spouting a load of of old tosh through not reading the OP properly. Lets just export the earth and say nothing.
Oh no !!!... The chief Rod is onto me ........ thought he was in bed!!Lets not , I'm already spouting a load of of old tosh through not reading the OP properly. Lets just export the earth and say nothing.
Slip of the tongue, I know it's not a cu lol, the cu is in my living room.That's not your CU. That's your supply head (looks like tncs so that's the earthing determined) and an isolator feeding out to your CU that's located somewhere else.You need to post a bigger picture next time
It didn't ...I made it up!!When did the workshop turn into a garage ?
even when moct ot tha leffers ara miccing or mised up yuo cna stll reed wot ist mentt tu saa :slapIt didn't ...I made it up!!Must learn to read the posts properly , I used to be the same with exam questions TBH, jumping to conclusions .
You're lucky I reply at all .....most of the letters have gone from my keyboard . Moond yoi I seen to be managaninf OJ so fat !!!
Perhips I shoylg boo a new ome , theur onlt chea[ .
also looks like bare 4mm earth from the twin along side the earth to the headTut tut tut at the head. 60A (but anyone could have written that on a 100A carrier with what looks like 10m tw&e. Earth cut off and exposed single insulation. Thats 3 codes
