Draft for public comment - changes to regulations
the test schedule result sheet is the same layout that i am using now... but i do like the new inspection form...
is it ok to start using these new forms?
You are not allowed to use the exact ones (copywrite) - but you can make a variation
Yes you can use the abode capture and paste into a graphic programme- or flash capture , etc
download and save the PDF... then print from PDF...
I have the file saved.
Adobe Acrobat 9 won't let you print it.
I have PDF Exchange viewer version 2 but that won't open it.
Any other PDF viewers that will open it and will allow you to print it.
All I want to do is print out the new format PIR forms so I can then make my own.
I have the file saved.Adobe Acrobat 9 won't let you print it.
I would wait this is only a draft and could change, if it does you would have wasted your timeheadbang
