davetheglitz
Electrician
Hi - just been dealing with a 3 phase dual rate digital meter - and the control wire for E7 is switched to neutral to activate the E7 contactor. Surely this is not to BS7671! Anyone had any experience of this?
correct. at least with manrose fans anyway. you can see the perm live connection runs stright to the fan connection at the other end of the boardIf I recall correctly a lot of bathroom timer fans do actually switch the neutral to trigger the fan...
Guinness
As Slippery said above , metering is not covered by 7671 , but are you saying it is now ?
