James Johnston
Active member
Yes once it's been inspected
Yes we are a main contractorJack of all trades
Of course I will I'm just trying to do as much of the work myself as I can there's no law against that it there ?
Look read and answer my questions here let me help you "you'll need an earth rod it's a long copper rod you hammer it into the ground and the green earth wire bolts onto it you can purchase one from an electrical factor or diy store"
As always safety first so remember to get a qualified electrician to check your work is safe before you switch on the supply.
James,Of course I will I'm just trying to do as much of the work myself as I can there's no law against that it there ?
Yes I bought an earth rod from Screwfix with clamp under a fiver hammered into the ground job doneAre you being serious?
Well time is short so try answering the question succinctly and btw the notifications have been sent to junk email so that's why the long delay I thought you electricians were making so much money you were still in the AlgarveJames,
Please tell me you are just posting this for a laugh, and it is all a wind up?
There are laws against shoddy workmanship, which could pose daner to others with electricity.
As far as your comment on “there's no law against it is there?”, well, yes there is actually.
The Health and Safety at Work erc. Act 1974, is a start.
Closely followed by the Electricity At Work Regulations 1989.
Then as you mention construction, there is the Construction Design and Management Regulations 2015.
Following that there is the Provision and Use of Work Equipment Regulations 1998.
Most of these have been amended since their publication, but, they are all still current law.
If I had time, I could give you the relevant regulations that your & your company seem to have breached as illustrated by your posts here.
Yep....according to Connections magazine £47k per yearWell time is short so try answering the question succinctly and btw the notifications have been sent to junk email so that's why the long delay I thought you electricians were making so much money you were still in the Algarve
and have you tested the rod to make sure you have an earth that is good enough to work - no you firkin haven't os you don't knoe how to test a rod and don't have the test gear to do it anyway. James, please stop trying to do work you haven't got a firkn clue about. I don't do plastering for a firkin good reason, I don't know how to do it properly, you clearly don't knoe how to do electrics properly, just looking at the **** termination of the earth into the board is enough to tell me everything I need to know about your skills in regards to electrics. As a main contractor you have serious legal liabilities for all trades working under your control, stop rying to cheapskate and get the right trades people to do the work. I'm suspecting you are winning contracts on low prices - don't waste your time on **** contracts, quote proper prices and use proper tradesmen to do the works.Yes I bought an earth rod from Screwfix with clamp under a fiver hammered into the ground job done![]()
A real man would have just cut a few of the strands off...they always put spares in anywayjust looking at the **** termination of the earth into the board is enough to tell me everything I need to know
Jack of all trades
