3
300TDI
Guest
Hi all
Hope you can throw some light on this
Customer has a 400a panel board which was installed but never used, he decided not to buy the machine in the end
He now has four smaller machines that will be sited two bays down in his factory
I have checked the loading on his new machines and this supply will be ample
But there is no distribution power in the bay he intends to use
So i will be disconnecting the board, pulling back the cable through the two bays and sending it down the bay, and re fitting the board there.
Would you do a minor works or eic for this
The cable length will not change
The installation method will not change
The existing cable is about 70 metres, and i will be re routing about 40 metres of it
Therefore i would not class this as a new installation
Maybe an alteration
Please correct me if you think i am wrong
Or should i do an eic to cover all aspects
Carl
Maybe an alteration
Carl
