Hi
I changed and relocated a consumer unit about 6 months ago for a client. Moved it from the garage and relocated it into the house, so that they could go ahead and convert the garage into a new room.
I did my usual routine, periodic inspection report first, everything checked out fine, so I changed and relocated the consumer unit, issuing the client with an installation certificate. Job done!!
The building work has now been completed but the builder doing the work extended the ring in the garage (now the new room in the house)
The building inspector will not sign the building off until a certificate has been issued for the new work i.e. the extension of the existing ring.
Do I inspect and test the work the builder has done and if I am happy then issue an Electrical Installation Certificate for the work, but this will be passing the work off as my own or do I issue a Periodic Inspection Report just for the new extended ring.
Will a Periodic Inspection Report on the one circuit satisfy the building inspector?
Thanks in advance
Thanks in advance
