Electrical Symbols, Formulas (Formulaes) & Equations Used in the Electrical Industry.
a1
Forum Founder
Feb 6, 2008
10,184
-1
Listed here is the webpage that I have put together containing the "Electrical Symbols, Formulas (Formulaes) & Equations Used in the Electrical Industry".
As soon as I get time I will put on the level Three (3) formulas, as well as the ones used to work out problems in the 302 & 303 written exams.
I hope you make good use of them.
www.electricianforum.co.uk/electricalformulas.html
Un-pinned as sadly the lined page no longer exists
I think a couple are wrong!!
Power is the rate at which work is done so
Power = Work / Time (shown as Power = work x time)
And the voltage calculation works if your talking about the Voltage across the resistor and the voltage across the Inductor so the symbols should read Vr and Vxl not just R and Xl.
The calculation shown would give impedance using resistance and inductive reactance as stated by andyc
I shall correct them on the next update - Thank You Gentlemen.
