difficult to comment on cases without details. If all else fails, tell landlord it's your problem for next 5 years if certified 'satisfactory'. Seems to appeal to landlords for some reason :^O
a verdict of Accidental Death. I may be wrong but if EAWR and H&S laws were applicable, the verdict would not have been accidental death? There are campaigns to get the law changed, http://hhgrahamjones.blogspot.co.uk/2012/06/keep-renting-safe-campaign.html but at the moment it is still non compulsory. however daft we my all think the law is!Recording an accidental death verdict, Coroner Andrew Cox said it was "inexplicable" there was no law on checking the electrics in rented homes.
Erm...I think think the OP committed suicide
didnt get a clear cut answer....so
for the OP if he ever comes back
there is no legal requirement
£75 or £150 his choice
:coatSingle tenant rented property answer = NO
Houses of multiple occupancy answer = YES.
steptoe said:erm,
I'll still say NO,
there is NO legal requirement either way,
unless you know of a statutory document that states otherwise,
or,
I may have read it all wrong, as usual.
Houses in Multiple Occupation (HMOs)
England and Wales
The
Management of Houses in Multiple Occupation (England) Regulations 2006
and the
Management of Houses in Multiple Occupation (Wales) Regulations 2006
require that every electrical installation in an HMO is inspected and tested at least
every five years by a suitably qualified person, who should provide a certificate giving
the results of the inspection. If your local housing authority asks in writing for this
certificate (Electrical Installation Condition Report - previously Periodic Inspection
Report), you must supply it within seven days of receiving the request.
steptoe said:what statutory document does that come from?
pubs and clubs requiring it for a license I think you will find is a condition of their licence, a completely different scenario, and in fact law,
just state the legality of a HMO or otherwise requiring a PIR or stop trying to pass off opinion as fact.
Duty of manager to supply and maintain gas and electricity6.—(1) The manager must supply to the local housing authority within 7 days of receiving a request in writing from that authority the latest gas appliance test certificate it has received in relation to the testing of any gas appliance at the HMO by a recognised engineer.
(2) In paragraph (1), “recognised engineer†means an engineer recognised by the Council of Registered Gas Installers as being competent to undertake such testing.
(3) The manager must—
(a)ensure that every fixed electrical installation is inspected and tested at intervals not exceeding five years by a person qualified to undertake such inspection and testing;
(b)obtain a certificate from the person conducting that test, specifying the results of the test; and
©supply that certificate to the local housing authority within 7 days of receiving a request in writing for it from that authority.
(4) The manager must not unreasonably cause the gas or electricity supply that is used by any occupier within the HMO to be interrupted.
Front page of the regulation will tell you that..steptoe said:OK, so you have stated a regulation that applies to England and Wales, what actual act does it come under,?
An electrical safety check must be commissioned prior to the commencement of a tenancy, and must be carried out by a competent person (a Part P qualified electrician in kitchens and bathrooms) to ensure that the electricity supply, and all appliances, are legal. This includes supplying instruction books where needed for safe use.
The only method of insuring that these appliances are safe is to have them tested by a trained electrical engineer using the portable appliance testing equipment, know as a (PAT) test.
Change of tack, since we all agree that regular inspection is / should be mandatory, can we all agree to sign up to the 'keep renting safe' campaign. Lets turn all this into action!
http://www.legislation.gov.uk/uksi/2006/372/introduction/made#f00001
i.e
The Secretary of State, in exercise of the powers conferred by section 234 of the Housing Act 2004(1), makes the following Regulations
http://www.legislation.gov.uk/ukpga/2004/34/section/234
:C
I doubt the ESC would state there is a legal obligation...
if there wasn't ??
just a reminder.. a HMO typically has 5 or more tenants and/or three or more stories high!
a two story 4 tenant student house is NOT a HMO!!!!
but then I am only a kn0b with all the gear and no idea!
No!so, it only applies to England then, its not a UK thing,
glad we knew that from the start, might have caused confusion otherwise. :|
at least binky is coming up with relevant links and not just trying to blag stuff that is irrelevant to at least three of the countries that make up the UK.
The National Assembly for Wales, in exercise of the powers conferred on it by sections 59(2), (3) and (4), 60(6), 63(5) and (6), 65(3) and (4), 83(2), (3) and (4), 84(6), 87(5) and (6), 232(3) and (7), 250(2), 258(2)(b), (5) and (6), 259(2)© of, and paragraphs 3 and 6(1)© of Schedule 14 to, the Housing Act 2004(1), makes the following Regulations:
