I supplied the inverter, consumer unit, cables etc. (bought from main distributors) I ran the cables to and from the loft, which he was able to inspect as nothing was under floorboards (i.e. In the garage, airing cupboard or loft. All the connections were done by the electrician. My questions still stands: Is it a legal requirement to issue an EIC after such work? If so who enforces it? Building control?
BS7671 wiring regulations are non-statutory...
Building Regulations Part-P is statutory...
All electrical work should be done in accordance with the guidance set out in BS7671...
But as DIY electrical work is legally permitted...
Unless someone is seriously injured due to an electrical fault or failure of part of the installation, it may never even be questioned... or investigated..!!!
However... while any tradesperson is doing work for a third party customer for monetary gain, the location where they are working, (be it an office / shop / factory / house / caravan / shed / etc).. Is a "Work-Place"!
As such it would come under the Health & Safety at Work legislation.. Which is statutory...
And H&S@Work will typically be referencing BS7671 for any electrical work-place issues.
Basically BS7671 is non-statutory BUT is does come under the umbrella of other various statutory legislation..
So... back to BS7671...
One of the basic requirements, (e.g regulations 644.1 and 644.4.201 and model forms in Appendix 6 ), is to issue appropriate electrical certificates for any additions or alterations that you have done to an installation. This may be an Electrical Installation Certificate, (EIC), or a Minor Works Certificate, (MWC)...
Either way, if you have energised a new circuit, or an alteration to an existing circuit, then various electrical tests should have been done to verify that in the event of a fault, the source(s) of energy will be disconnected fast enough to prevent danger to people property or livestock..
These test results should be documented on the appropriate electrical certificate and given to the person ordering the work.
Do you have any written estimate/quotation/invoice, (printed / e-mail / text etc), with this persons name / business / contact details etc, for the work you requested to be done?
If this was all verbal... you may be up poop-creak, without a paddle!!!
But a few general rules of thumb....
[1] NICEIC don't normally get involved in contract disputes...
[2] NICEIC are happy to get involved with miss-use of logo problems..
[3] It is always easier to investigate claims where there is some form of written contract / quote / invoice.. etc..
[4] Trading standards may be the avenue to pursue if NICEIC are reluctant to do anything?
My gut feeling is that you do have good grounds to complain...
Its just finding the best avenue / door-to-push, to gets things moving!
It sounds to me like someone was after a quick easy-money, no-hassle job, without being prepared to stand-up and take responsibility for the work they have done!!!
Thus NO paper-trail!!!!!! (AKA cowboy - scumbag)
Personally I would have thought that a reputable electrician will either..
(a) walk away and don't do the work..
or..
(b) do the work and do the tests and issue certificates...
Hope you get it resolved!
