Hi all,
Thank you in advance for any comments.
I recently found on two occasions that I was getting a very mild electric shock from my shower taps when in the shower. I was trying to trace the issue and found that even with all power off at the fusebox a voltage detector immediately goes off when touching the bathroom taps, and also all the pipework in the loft including the combi boiler. I then went outside and also found a voltage both sides of the gas meter including before the ECV but slightly harder to detect. Power has not cut at any point and all earthing in my property seems ok.
Any ideas what on earth could be causing this? I do have an electrician booked but not for a few days. Some things I read online suggest it could be a neighbour causing it - I wouldn’t put it past one of them to have cut corners. And is it immediately dangerous with regards to gas and the boiler?
