HiThe black box in the bottom LH corner is a controller to switch on the OFF peak supply, the Meter above is a two tariff meter and the rhs meter is a single tarriff. The bottom right is the service cut-out with service fuse.
Is the meter in the top LHC for one property and the meter in the top RHC for another property?You have 2 supplies - the property will be on Economy 7 (or similar) with the remote teleswitch bottom left to switch over. You have 2 main fuses.
