The equipment is located in a cupboard above my bedroom door. You need a ladder to get access. The DNO guy definitely didn't look inside, so not sure why he reported that it wasn't a possible fused neutral situation.It was once... but a solid link could have been put in many moons ago.
You don't know til someone looks inside..?
Supply cable could do with an upgrade too.
The earth wire from the CU goes to a block. From that are two wires that go into the loft, one goes through the wall to the outside of the building and is attached to somewhere in the external gas meter box, the other goes to the back of the flat and then comes back down and is attached to the incoming water supply pipe.I picture of your consumer unit would be interesting to see where you get your earth from.
so you have no earth then.The earth wire from the CU goes to a block. From that are two wires that go into the loft, one goes through the wall to the outside of the building and is attached to somewhere in the external gas meter box, the other goes to the back of the flat and then comes back down and is attached to the incoming water supply pipe.
Is this something else I need to get sorted?so you have no earth then.
all you have is the bonding to the gas and water pipes, but no actual earth either from the supply, or from an external rod.
In the process of upgrading the cable, you may well find they give you a PME earth, in which case you can use that and job's a good un.Is this something else I need to get sorted?
