Hi all,
This is going to seem like a stupid post, but I have just received an electric bill through and i just don’t see how I have used that much power.
I moved in on 27th Oct. 2 bed flat, 13 years old, all electric. From 27oct-21Nov i used 271 kwh of day rate and 200kwh of night, actual readings.
Usage details:
-i live alone
-i’m tight as f*ck, e.g always turn lights off
-half way through i replaced all lighting with LED 5watt, so each room is only 15w to light
-no dish washer or tumble drier
HEATING
-i have a Dimplex SH12 series B in the hall but that is currently not working (see other post)
-in the lounge I have a Dimplex Duo 500n Series B, input is half way, output varies between a third and a half
-in the 2 bedrooms i have small Dimplex convection heaters that come on for an hour each morning, 5-6am just to take chill off
HOT WATER
- range tribune, direct 210L, TPR 15.
there is one wired switch going into the middle of the tank, i always leave this on, and it is lit up. There is another wired switch that goes to the bottom of the tank, this is on but not lit up at the wall?
all other usage is average or below eg cooking etc. Is something not working overnight and using day rate instead? I have lived in these flats before and Im sure the electricity wasnt this expensive for 2 of us?
Any advice would be appreciated.
thank you.
Martin.
Usage details:
-i live alone
HEATING
HOT WATER
thank you.
Martin.
