tom1,
I accept this, but, you still should do the full design calcs if you are in doubt that the circuit will comply with the std criteria.
The high loads at the start of the "now" radial will have an affect on the terminal voltage.
You should calculate this using Kirchoff's current laws to ensure that your radial design complies with the volt drop constraints.
