extension15
Distinguished Member
- Feb 13, 2008
- 1,658
- 0
Any of you guys experienced this procedure (Throat or Rear)??
:_|
:_|
(I actually thought about that one earlier)Are they going to meet up in the middle?? ; )
classic!Are they going to meet up in the middle?? ; )
if they use the same scope make sure they go down your throat first.........Well, I'm having both done on the same day.. :|
( : O)
As I've had a problem for yearsDon't envy you mate,, hope it all works out OK
Fleet is the medication to clear the insides...I understand it's the laxatives and enema is the worst part of the procedure.Also you can't drive home.
trust you to wake up when talk comes round to poking things in persons orifice's! ; \if they use the same scope make sure they go down your throat first.........
Sorry M8, your too slow, I'd already thought of that one....if they use the same scope make sure they go down your throat first.........
I am likely to be the only member on here to have actually performed endoscopy on both dogs and horses!Sorry M8, your too slow, I'd already thought of that one....Anyway I don't think thay use the same piping twice..
:^O
Oh.....I am likely to be the only member on here to have actually performed endoscopy on both dogs and horses!
The tubing isn't changed between uses and patients. The scope is cleaned and cold sterilised (usually in glutaraldehyde).
Thanks, comes with age, but as I say it is a long term problem, so I'm hoping to get to the bottom of it..EXT,hope it all goes well or you sir. :|
I ain't ever had anything like that............
My good lady has though !
