Eurosec GTA 816 manual
Dambo
Oct 7, 2009
473
Hey there,
Just wondering if anyone might have a copy of the Eurosec GTA 816 installation manual? Just trying to install a speech dialler but not sure where to wire it into on the control panel as the instructions which come with the speech dialler don't tally up with the terminals on the control panel.
Could you scan and upload the wiring diagram that came with the dialer? We may be able to help you regardless of the panel wiring.
---------- Post Auto-Merged at 19:57 ---------- Previous post was made at 19:57 ----------
Sub note I think the gaurdtec alarms are the same type.
Does anyone know which terminals to connect the speech dialler into on the Eurosec 816 alarm?
Looks easy enough, but to confirm and make sure you connect to the correct terminals can you upload a picture of the alarm panel connectors. It may only require two connections one of which will be the fire connector, some are connected direct to the bell!
Your speech dialler can be wired direct to the bell terminals on the SAB. Just observe the + and - and it should be straight forward.
Thanks Manator. Just to confirm, only 2 wires are required - Is it bell+ to INH and bell- to IP1?
